1 of 5
Wyze Solar Panel
Record for longer. Designed for Wyze Cam Outdoor v1 or Wyze Cam Outdoor v2.
TOTAL:
$90.000,00
Features
  • Extend the length of time you can keep your Wyze Cam Outdoor recording without having to bring it back inside to recharge.
  • IP65 weather resistant and dustproof.
  • Mount it anywhere with a 360 degree freestyle mount and a 13-foot weatherproof power cable.
User Guide
  • Wyze Cam Outdoor recharge frequency varies based on device settings, motion notifications, and sun exposure in the area of placement.
  • For the most sunlight, position your Wyze Solar Panel so that it’s facing south and is tilted upward at a 30º angle.
  • Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
Tech Specs
  • Color: White
  • Dimensions: 173 mm x 120 mm x 17 mm
  • Solar power rating: 2.5W, 5VDC
  • Micro USB cable length: 13 ft (4m)
  • Waterproof level: IP65
In the Box
  • Solar panel x1
  • Wall mount x1
  • Adapter cable x1
  • Screws x3
  • Wall anchors x3
  • Quick start guide x1
