1 of 5
Wyze Cam v3
The best. Now better. Your next home security camera.
Our award-winning wired smart camera is back with illuminating Color Night Vision and new outdoor-friendly IP65 weatherproofing. Keep an eye on what matters most - indoor or out, rain or shine, light or dark.
Choose your style
TOTAL:
¥6,400 Shipping Included
15-day hassle-free returns.
Features
Color Night Viewing
Starlight CMOS Sensor helps you to see in ultra low-light conditions.
Wyze Cam v3 is capable of seeing in color at night with very limited lighting. You can even use it to watch the stars or take a time lapse of the stars.
Indoor and Outdoor Use
IP65-rated weatherproof with extreme temperature tolerance from -4°F to 113ºF, the camera can be mounted anywhere inside or outside your home and stand up to any weather conditions. IMPORTANT NOTE: Wyze Outdoor Power Adapter (sold separately) required for outdoor use.
Crisp HD Image
An improved sensor and lens lets the v3 capture extraordinary images and videos in any light. It’s the best in its class.
Versatile Mounting
Put your Wyze Cam v3 anywhere you want.
Your camera can be mounted 3 ways - with the easy magnetic mount, secure screw mount, or the¼” mount onto your existing mount.
Real 2-Way Talk
Say goodbye to push-to-talk.
Wyze Cam now comes with simultaneous 2-way communication. Talking to your family, pets and visitors is just like making a phone call.
Dual IR light System
The Near-IR lights for indoor use are invisible to the human eye so you won’t be annoyed by red dots. The far-IR light for outdoor use, to illuminate farther and see clearer.
Mini Siren Feature
Use the improved speaker as a siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
Tech Specs
Wyze Cam v3 Device Details
Color
White, with black accents
Materials
Body: Polycarbonate
Lens: Glass + Plastic
Camera Dimensions
52 mm (L) x 51 mm (W) x 58.5 mm (D)
Camera Weight
<98.8g
Phone Compatibility
Android 5.0+
iOS 9.0+
Night Vision
IR Lights: 4x940 nm, 4x850 nm
Day/Night Vision
Audio
Mic: ECM
Speaker: 80db, waterproof
Simultaneous 2-way Talk
Siren
Powering methods
Power Adapter: Indoor 5v/1A
Cable: 6 Feet Flat USB Cable
Sensor
CMOS Starlight Sensor
LED Indicator
Front. Red + Blue.
Connectivity
2.4GHz WiFi
Storage
Local Storage (microSD card required)
Cloud
Operating Temperature
-5°F - 113°F (-20°C - 45°C)
Weather Resistance
IP65 Weather resistant
Indoor/Outdoor
Certifications
FCC, IC, UL and IP65 Certified
Languages
English
Warranty
1-Year
In the Box
Wyze Cam v3 x1
Quick Start Guide x1
Wall Mount Plate x1
Wall Mount Plate Tape x1
Screw Kit x1
Indoor USB Power Adapter x1
6 Feet Outdoor Rated USB Cable x1
1080p Color Night Vision
See more clearly at night in full color.
Indoor/Outdoor
Capture moments indoors and outdoors with IP65 weather resistance.
Fully upgraded
More processing power. More mounting options. More frames per second.
Brighter, Bolder, & Better than ever
An all-new Starlight Sensor illuminates the outdoors in full color while weather resistance lets you capture life outside. Performance upgrades across the board make this Wyze’s most powerful smart cam ever.
Look on the bright side
Pierce through darkness with the all-new Starlight Sensor. This low-light amplifier shows dark areas in vivid, spectacular detail unseen even to the human eye.
Wyze Cam v2
Wyze Cam v3
Wyze Cam v2
Wyze Cam v3
Wyze Cam v2
Wyze Cam v3
Starlight Sensor
The Starlight CMOS sensor sees in environments up to 25x darker
ƒ/1.6 aperture
Reveals greater detail at night by capturing 2x more light
Starlight ISP
Reduces noise from low light & sharpens the image for astonishing clarity.
Bold design with the outdoors in mind
It’s time to take Wyze Cam outside. All-new IP65 weather & dust resistance truly lets you see everything around your home, inside and out
* Wyze Cam v3 is wired allowing for continuous recording**. Requires Wyze Outdoor Power Adapter (sold separately) for outdoor use. **Requires microSD card (sold separately)
Better in all ways that make you go, "Wow!"
We didn’t just upgrade the look - we upgraded the whole fricken thing (Brighter Night Vision, Invisible IR LEDs, Versatile Mounting, Mini Sirin).
2x faster processor
Renders images and streams video faster
Smoother video playback at 20 FPS
Wider field of view
130º FOV sees more than ever before
You loved these features. So we kept them.
Motion and Sound DetectionLook & listen for motion & sound. Wyze Cam sends your phone an alert and begins recording when either is detected.
Motion Detection Zones
24/7 Continuous Recording
Capture and view up to 3 days of continuous video with a 32 GB microSD card (sold separately).
Smoke & CO Alerts
Receive an alert the moment Wyze Cam hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
