1 of 7
Wyze Cam v3 Pro
2K home security cam with a built-in spotlight and on-device Edge AI.
Meet the all-new pro version of our #1 best-selling camera. 2K resolution. Built-in spotlight. Integrated siren. Edge AI. And all the best IP65 indoor/outdoor, two-way audio, microSD-ready, Color Night Vision goodness you've come to expect from the v3. From pet cam to security cam and back. The best. Now even better.
Choose your style
TOTAL:
¥10,300 Shipping Included
Features
2K Video Resolution—View the Live Stream and Events in clarity and detail, whenever you need it, with crisp, clear 2K resolution.
Integrated Spotlight and Built-In Alarm—A motion-activated, 80-lumen spotlight for more detail in your videos, more light along your walkway, and more deterrence for unwanted visitors. Plus an 89-decibel, user-activated alarm when you need to deter them even more.
Faster detections with Edge AI—A powerful, dual-core 1.2 GHz processor and 8 TOPS neural network accelerator for near-instant person detections thanks to AI that doesn’t rely on the cloud.
24/7 Recording*—microSD card-ready for uninterrupted 24/7 recording. Up to 15 days (in full 2K resolution) on one 128 GB card.
IP65-Rated Weather Resistance**—All-weather, year-round, indoor and outdoor security.
Two-Way Audio—Speak in real time to anyone in front of the camera.
Color Night Vision—4MP Starlight sensor amplifies low light and shows dark areas in vivid, unbelievable detail.
Brand-New User Interface—A completely redesigned user experience with simplified event navigation, customizable detection zones, and the all-new Smart Focus feature.
Works with Alexa and Google Assistant—Receive alerts and use voice commands to check and manage your devices. You can also create schedules and automations in the Wyze app.
*MicroSD card (sold separately) required
**Wyze Outdoor Power Adapter (sold separately) required for outdoor use.
Tech Specs
Finish: Matte White
Dimensions: 2.05 in x 2.05 in x 2.3 in (52 mm x 52 mm x 58.5 mm)
Weight: 4.23 oz (120 g)
Power Cable Length: 6ft (1.8 m)
Mounting Method: Magnetic, Screw, Tape
Ports: 1 microUSB
Power Adapter Input: 110-240V(AC/DC)
Power Adapter Output: 5V/2000mA
CPU: 1.2 GHz
Memory: 1 GB
Image Sensor: CMOS (2560 x 1440)
Digital Zoom: 8x
Field-of-view: 116°
Night Vision: 4 IR LEDS(850nm)+ 2 Spotlight (5000K, 70 lumen)
Video Encoding: H.264
Video FPS: Daytime—20 fps; Nightime—15 fps
Video Resolution: 2560x1440 (2K)
Audio: Built-in speaker & microphone; 2-way audio; Noise & echo cancellation
Alerts: Push notifications
Local Storage: Supports up to 256 GB microSD in FAT32 format
Wi-Fi: 802.11 b/g/n, 2T2R 2.4 GHz (5 GHz Wi-Fi not supported)
Integrations: Alexa, Google Assistant, IFTTT
Compatibility: iOS 14.0+, Android 7.0+ Operating Temperature: -4°F - 131°F (-20°C - 55°C) Storage Temperature: -40°F - 158°F (-40°C - 70°C)
Weather Resistance: Indoor and Outdoor (IP65)
In the Box
Wyze Cam v3 Pro x1
USB Cable x1
Power Adapter x1
Wall Plate x1
Mounting Tape x1
Screws & Expansion Tubes x2
Quick Start Guide x1
2K Video with Color Night Vision
Built-in Spotlight and Integrated Siren
Powerful Processor with Edge AI.
Indoor/Outdoor Weather Rated IP65
Meet the v3 Pro.
Everything you love about Wyze Cam.
Now with better AI, better night vision, and better resolution.
Our most popular camera. Reimagined.
Crisp, clear 2K resolution.
See what you need to see and read what you need to read, from faces to license plate numbers.
Faster detections with Edge AI.
Edge AI detection doesn't rely on the cloud to do its thinking.
For Wyze Cam v3 Pro, that means free, near-instant person detection, right when you need it, with no subscription required.
An all-new cam, with a brand-new app experience.
Our redesigned user interface.
Get more from the Wyze app than ever before.
All-New Live View
Handy tools at your fingertips, from spotlight and siren controls to the new Smart Focus feature and simplified event review.
Playback Reimagined
All the playback tools you're used to, plus an easy-to-scan Recent Events section to help you navigate your footage quickly.
Customized Detection Zones
Tell Wyze Cam v3 Pro exactly where and what you want it to watch. Get notifications only for detections within your customized zone.
Insert a microSD card for 24/7 recording.
Capture and view up to 15 days (in full 2K resolution) with a 128 GB microSD card (sold separately).
Moments. Captured.
More than a security camera, inserting a microSD card turns your Wyze Cam v3 Pro into a 24/7 video diary of candid moments and everyday life.
Indoor/Outdoor Weather Resistance.
Wyze Cam v3 Pro is IP65 rated for all-weather, year-round, indoor and outdoor security.
Two-way audio.
Talk, interact, and let people know you see them, whether you're confronting a stranger, or checking in on a loved one.
Works with Alexa and Google Assistant.
A great way to livestream baby or pet cams, 24/7. Plus, receive alerts, use voice commands to check and manage your livestreams, or create schedules and automations in the Wyze app.
