1 of 5
Wyze Cam Pan v2
Take it for a spin. Now with Color Night Vision.
The internet’s favorite panning, tilting, and zooming 1080p smart camera is back to help you keep an eye on the entrances, pets, and babies inside your home! The new Color Night Vision brings detail, color, and definition to even the smallest details in dimly-lit rooms.
Choose your style
TOTAL:
RM136.00 MYR + Shipping
15-day hassle-free returns.
Features
Color Night Vision
Wyze Cam Pan v2’s Starlight CMOS Sensor helps you to see in ultra low-light conditions.
This camera is capable of seeing in color at night with very limited lighting. You can even use it to watch or even take a time lapse of the stars.
Pan/Tilt/Zoom
Use the control panel in the Wyze app to pan and tilt the camera for a 360° live view. Pinch zoom the live stream screen to zoom up to 8x. You can adjust the rotation speed (up to 110° per second) in the Wyze app.
Pan Scan
Wyze Cam Pan v2 automatically scans its surroundings by rotating to up to 4 custom waypoints. It pauses for 10 seconds at each waypoint before moving on to the next one.
1080p Full HD
Live streaming, recording, and playback are all available in clear and sharp 1080p HD resolution. Toggle between SD and HD to fit your needs.
Motion Tracking
Wyze Cam Pan v2 auto-tracks any moving object detected within its field of view. You can turn this feature on or off in the Wyze app.
Motion Tagging
Highlight motion in both Live Stream and Playback modes.
Live Streaming
View what’s going on in real time and record videos or take pictures saved directly to your phone.
Real 2-Way Audio
Say goodbye to push-to-talk.
Wyze Cam Pan v2 has simultaneous 2-way communication. Talking to your family, pets, and visitors is just like making a phone call.
Night Vision
Wyze Cam Pan v2’s enhanced night vision distinguishes 18 variations of gray and provides clear images up to 30 feet away.
Motion and Sound Detection
When the camera detects motion or sound, it will record a 12-second video that is securely stored in the AWS cloud.
Motion Detection Zone
Create a custom detection zone to only trigger Event Videos for motion detected within a specific area of the camera’s field of view.
Smart Sound Recognition
Wyze Cam Pan v2 recognizes the unique tonal patterns of smoke alarms and CO monitors to alert you to these specific emergencies.
Push Notifications
Receive a push notification to view an Event Video when motion or sound is detected and recorded.
Alert Scheduling
Set an alert schedule to automatically turn on and off motion and sound detection at specific times of the day.
Free, Rolling, 14-Day Cloud Storage
You have free access to saved motion and sound-triggered Event Videos for rolling 14 days for the life of the product.
Secure AWS Cloud Storage
Wyze Cam Pan v2 uses end-to-end encryption for uploading and downloading Event Videos to and from the AWS cloud.
Continuous Recording
Footage can be recorded and stored to a microSD card (sold separately) continuously. Older files are automatically overwritten when storage reaches capacity.
Time Lapse
Set the time frame and intervals to easily create custom time lapse videos and save them locally to a microSD card (sold separately).
Playback
When a microSD card (not included) is installed, users can view videos in Playback mode by scrolling through the timeline and pinch zoom the timeline for easier navigation.
Sharing
Use the Wyze app to share your camera with other users.
Flexible Installation
The ¼” – 20 threaded screw hole in Wyze Cam Pan v2’s base works with standard camera mounts and can be mounted to any surface.
Mini-Siren Feature
Use the improved speaker as a siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
Tech Specs
Wyze Cam Pan v2 Device Details
Color
White
Finish
Matte
Materials
Body: Polycarbonate
Lens: Glass + plastic
Camera Dimensions
127.5 mm (H) x 60 mm (W) x 60 mm (D)
Camera Weight
8.78 oz (249 g)
Ports
1 micro USB
LED indicator
Front: Red + Blue.
Phone Compatibility
Android 7.0+
iOS 12.0+
Night Vision
IR Lights: 6x940 nm
Illuminates up to 29.6 feet (9 m)
Day/Night Vision
Audio
Built-in speaker and microphone
Class-D power amplifier
Powering Methods
Power Cable Length: 6 feet (1.8 m)
Power Adapter Input: 110-240V (AC/DC)
Power Adapter Output: 5V/2000mA
Base Screw Hole
1/4″ – 20
CPU
1.5GHz
Memory
128 Mb
Camera
Resolution: 1920 X 1080 (1080p)
Lens: F1.6 aperture, 3.2mm focal length
Image Sensor: 1/2.9'' CMOS
Digital zoom: 8x
Field of View: 120° lens
Rotation Speed
Up to 110° per second
View Range: 360° horizontal, 93° vertical
Audio
Video
H.264 encoding
Day time video: 20 FPS
Night vision: 15 FPS
Alerts
Push notifications
Cloud Storage
Free rolling 14 days of alert videos stored in the AWS Cloud
Local Storage
Supports 8 GB, 16 GB and 32 GB microSD cards in FAT32 format
Data Security
End-to-end encryption
HTTPS secure transfer protocol
AES 128-bit encryption
Data Usage
1-2 MB per minute in SD, or 4-7 MB per minute in HD
WiFi
802.11 b/g/n 2.4 GHz (Does not support 5 GHz network)
Supports WPA and WPA2 protocols
Connectivity Requirements
Upload speed is 1.0 Mbps for SD and 1.5 Mbps for HD
Operating Systems
Supports iOS 12.0 and Android 7.0 or later
Operating Temperature
32℉ – 104℉ / 0°C – 40 °C
Operating Humidity
<90% at 104℉ / 40°C
Weather Resistance
Indoor use only
Certifications
FCC, IC, UL
Languages
English
Warranty
1-Year
In the Box
  • Wyze Cam Pan v2 x1
  • 6′ Micro USB Cable x1
  • Power Adapter x1
  • Quick Start Guide x1
Pan & Tilt
360° horizontal and 93° vertical range.
1080p Color Night Vision
See more clearly at night in full color.
Invisible Infrared Lights
Subtle and discreet at night.
Security-Focused
Designed with safety in mind.
See the whole room in under 3 seconds
Follow the action wherever it goes with automatic motion tracking and 360° of coverage. It's like having a guard owl on duty 24/7. Except you don't have to feed it Tootsie Pops.
Let Pan Scan™
Patrol your room with Pan Scan™. Set the camera’s patrol route with up to 4 custom waypoints.
Catch every story in color, even at night.
Say goodbye to black and white clips that look like vintage newsreel footage. Our award-winning Starlight Sensor illuminates details in full color even in low light.
Wyze Cam Pan
Wyze Cam Pan v2
Wyze Cam Pan
Wyze Cam Pan v2
Wyze Cam Pan
Wyze Cam Pan v2
  • Starlight Sensor
    The Starlight CMOS sensor sees in environments as dark as 0.1 lux
  • ƒ/1.6 aperture
    Reveals greater detail at night by capturing more light
  • Wide Field of View
    120º FOV sees the whole picture.
Connect and Protect
Greet, command, and praise your two-legged or four-legged children from anywhere like a not-at-all anxious helicopter parent. Press the siren button in the Wyze app to scare off unwanted guests.
Invisible infrared lights
You know those red dots that turn on when a camera switches to night vision and it looks like The Terminator? Yeah, ours doesn't do that. Wyze Cam Pan v2 lights stay invisible so they don't disturb furry friends or baby Sarah Connors.
Automatically track the action.
Squirrel! Automatically detect and track motion like a caffeinated watch dog. Beefed-up processing power follows real-time movement faster than ever!
And even more smart features.
24/7 Continuous Recording
Capture and view up to 3 days of continuous video with a 32 GB microSD card (sold separately).
Instant Notifications
Wyze Cam Pan v2 automatically records a 12-second Event Video when it detects motion or sound. Turn on push notifications to stay on top of things without having to constantly monitor the app.
Smoke & CO Alerts
Receive an alert the moment Wyze Cam Pan hears a Smoke or CO alarm go off. Set it to record a video during this time.
