1 of 6
Wyze Video Doorbell Pro
Battery-powered HD smart doorbell with 30 second install.
Wider view. Higher resolution. Extraordinary price. Wired or Wireless with battery power. Install in 30 seconds.
Choose your configuration
TOTAL:
₱6,800.00 Shipping Included
Features
  • 30-Second, Wire-Free Installation
  • Optional Hardwiring for Continuous Power
  • 1:1 Aspect Ratio & 1440p Full HD Video
  • Up to 6 Months of Battery Life
  • Dual-Band WiFi Connectivity 2.4G Hz/5 GHz
  • Instant Notifications
  • Motion Detection, Smart Alerts & Video Recording
  • IP65 Weather-Resistant
  • Cam Plus Compatible
Tech Specs
Color
Doorbell: White, with black accents
Chime: White
Materials
Body: Polycarbonate
Lens: Glass + Plastic
Weight
Doorbell: 210 g
Chime Pro: 100 g
Dimensions
Doorbell: 141 mm x 46.5 mm x 28 mm (5.5 in x 1.8 in x 1.1 in)
Chime Pro: 69.85 mm x 41.27 mm x 69.85 mm (2.7 in x 1.6 in x 2.7)
Compatibility
Android 7.0+ and iOS 12.0+
Night Vision
IR Lights: 6 x 850mm
Day/Night Vision
Audio
Mic: ECM
Speaker: 80 dB, waterproof
Simultaneous 2-way talk
Battery
Battery Life: 3-6 months of battery life with normal use
Battery spec: 2x3250 mAh/7.4V rechargeable batteries (non-removable)
Resolution: 1440x1440p Full HD
Field of view: Horizontal 150°, Vertical 150°
Connectivity
2.4 GHz and 5 GHz WiFi
Operating Temperature
-4℉ - 120℉ (-20°C - 49°C)
Weather Resistance
IP65 Weather resistant
Certifications
FCC, IC, UL and IP 65 Certified
Warranty
1-Year
In the Box
  • Wyze Video Doorbell Pro ×1
  • Wyze Chime Pro(US Plug) ×1
  • Back Plate For Screws ×1
  • Back Plate For 3M Tape ×1
  • 3M Tape x1
  • T8 Screwdriver ×1
  • Wire Nuts ×3
  • Bracket Screws ×3
  • Extension Wires ×2
  • Expansion Tubes ×3
  • USB Charging Cable ×1
  • Quick Start Guide ×1
  • Battery-powered front porch protection.
    Designed from the ground up to deliver a luxurious user experience, Wyze Video Doorbell Pro can be easily installed wired or wire-free. Easily mount with screws or the screw-free adhesive plate and quickly view it all from anywhere in crystal-clear HD resolution.
    • “Unmatched value for under $100.”
    • “For the price, it’s difficult to beat.”
    • “Punches well above its price point.”
    1 of 3
    Welcome mat? You can see that too.
    Wyze Video Doorbell Pro features a head-to-toe, ultra-wide viewing angle, so not only can you see the package at your doorstep, but even the house down the street.
    Faster notifications with a Wi-Fi Extender chime.
    Most battery-powered video doorbells have sluggish notifications.
    Ours includes a dual-band Wi-Fi Extender chime which stays connected to both your doorbell and Wi-Fi for lightning-fast notifications while also conserving your doorbell's battery life.
    Integrated with Alexa and Google.
    Use your Amazon Echo smart speakers as extra doorbell chimes throughout your home. Command live video feeds to appear on your Echo Show and Google Home devices, even get an alert from Alexa if a person is detected at your door, with Cam Plus.
    Motion-activated security light.
    When motion is detected, a security light around the doorbell's button will gradually glow blue to alert anyone at your front door that they are on camera and being recorded.
    Quickly tell the deliver driver where you want your package placed by simply pressing the "talk" button in the Wyze app.
    You can also use preset quick responses to have the doorbell say things like:"Be there shortly" or "Leave the package at the door."
    Hear your doorbell ring, chirp, or bark.
    Choose between 20 unique tunes and 8 sound levels to find the perfect chime for you, even scare off potential intruders with a dog bark.
    ✓ Chime Included
