Wyze Window Mount
Reduces glare. Only for Wyze Cam v3/Pro.
Upgrade your exterior security by attaching a Wyze Cam v3 or Wyze Cam v3 Pro to your window. Mount your cam on a glass surface with this accessory and enjoy a clear view free of glare or reflection.
TOTAL:
$15.00
+ Shipping
Features
Window Mount for Wyze Cam v3
Get more flexibility by adding a window mount designed for Wyze Cam v3.
The window mount allows you to attach a Wyze Cam v3 to any window. Mount your camera exactly where you want it and enjoy a view free of glare or reflection even through glass.
Functionality
- View through a window without glare or reflection
- Turn Wyze Cam v3 into a window-mounted security camera
- Monitor outside without needing to run wiring outdoors
- Take advantage of Color Night Vision even through glass
Use Cases
- Watch for package deliveries with a Wyze Cam v3 mounted on a nearby window
- Monitor important areas around your home with a Wyze Cam v3 mounted on a nearby window
Comparison Images
Without window mount
With window mount
Tech Specs
Dimensions: 90 mm x 63.8 mm x 11.45 mm
Weight: 1 ounce
Warranty: 1 year
In the box: Wyze Cam v3 Window Mount
- Choosing a selection results in a full page refresh.
