1 de 5
Wyze Cam v3
Lo mejor. Ahora mejor. Su próxima cámara de seguridad para el hogar.
Choose your estilo
TOTAL:
$127.000,00 Envío incluido
Devoluciones sin problemas de 15 días.
Features
Color Night Viewing
Starlight CMOS Sensor helps you to see in ultra low-light conditions.
Wyze Cam v3 is capable of seeing in color at night with very limited lighting. You can even use it to watch the stars or take a time lapse of the stars.
Indoor and Outdoor Use
IP65-rated weatherproof with extreme temperature tolerance from -4°F to 113ºF, the camera can be mounted anywhere inside or outside your home and stand up to any weather conditions. IMPORTANT NOTE: Wyze Outdoor Power Adapter (sold separately) required for outdoor use.
Crisp HD Image
An improved sensor and lens lets the v3 capture extraordinary images and videos in any light. It’s the best in its class.
Versatile Mounting
Put your Wyze Cam v3 anywhere you want.
Your camera can be mounted 3 ways - with the easy magnetic mount, secure screw mount, or the¼” mount onto your existing mount.
Real 2-Way Talk
Say goodbye to push-to-talk.
Wyze Cam now comes with simultaneous 2-way communication. Talking to your family, pets and visitors is just like making a phone call.
Dual IR light System
The Near-IR lights for indoor use are invisible to the human eye so you won’t be annoyed by red dots. The far-IR light for outdoor use, to illuminate farther and see clearer.
Mini Siren Feature
Use the improved speaker as a siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
Tech Specs
Wyze Cam v3 Device Details
Color
White, with black accents
Materials
Body: Polycarbonate
Lens: Glass + Plastic
Camera Dimensions
52 mm (L) x 51 mm (W) x 58.5 mm (D)
Camera Weight
<98.8g
Phone Compatibility
Android 5.0+
iOS 9.0+
Night Vision
IR Lights: 4x940 nm, 4x850 nm
Day/Night Vision
Audio
Mic: ECM
Speaker: 80db, waterproof
Simultaneous 2-way Talk
Siren
Powering methods
Power Adapter: Indoor 5v/1A
Cable: 6 Feet Flat USB Cable
Sensor
CMOS Starlight Sensor
LED Indicator
Front. Red + Blue.
Connectivity
2.4GHz WiFi
Storage
Local Storage (microSD card required)
Cloud
Operating Temperature
-5°F - 113°F (-20°C - 45°C)
Weather Resistance
IP65 Weather resistant
Indoor/Outdoor
Certifications
FCC, IC, UL and IP65 Certified
Languages
English
Warranty
1-Year
In the Box
Wyze Cam v3 x1
Quick Start Guide x1
Wall Mount Plate x1
Wall Mount Plate Tape x1
Screw Kit x1
Indoor USB Power Adapter x1
6 Feet Outdoor Rated USB Cable x1
Visión nocturna en color de 1080p
Vea más claramente por la noche a todo color.
Bajo techo, en exteriores
Capture momentos en interiores y exteriores con resistencia a la intemperie IP65.
Completamente actualizado
Más potencia de procesamiento. Más opciones de montaje. Más fotogramas por segundo.
Más brillante, más audaz y mejor que nunca
Un nuevo sensor Starlight ilumina el exterior a todo color, mientras que la resistencia a la intemperie te permite capturar la vida al aire libre. Las actualizaciones de rendimiento en todos los ámbitos hacen de esta cámara inteligente más poderosa de Wyze.
Mirar el lado bueno
Atraviesa la oscuridad con el nuevo Starlight Sensor. Este amplificador de poca luz muestra áreas oscuras con detalles vívidos y espectaculares que ni siquiera el ojo humano puede ver.
Wyze Cámara v2
Wyze Cámara v3
Wyze Cámara v2
Wyze Cámara v3
Wyze Cam v2
Wyze Cam v3
Sensor de luz estelar
El sensor Starlight CMOS ve en entornos hasta 25 veces más oscuros
Apertura ƒ/1.6
Revela más detalles por la noche al capturar 2 veces más luz
Proveedor de servicios de Internet Starlight
Reduce el ruido de la poca luz y agudiza la imagen para una claridad asombrosa.
Diseño atrevido con el aire libre en mente
Es hora de sacar Wyze Cam afuera. La nueva resistencia a la intemperie y al polvo IP65 realmente le permite ver todo alrededor de su hogar, por dentro y por fuera
* Wyze Cam v3 está cableado para permitir la grabación continua**. Requiere el adaptador de corriente para exteriores Wyze (se vende por separado) para uso en exteriores. **Requiere tarjeta microSD (se vende por separado)
Mejor en todos los sentidos que te hacen decir "¡Guau!"
No solo mejoramos el aspecto, mejoramos todo el maldito asunto (visión nocturna más brillante, LED IR invisibles, montaje versátil, Mini Sirin).
Procesador 2 veces más rápido
Renderiza imágenes y transmite videos más rápido
Reproducción de video más fluida a 20 FPS
Campo de visión más amplio
130º FOV ve más que nunca
Te encantaron estas características. Así que los mantuvimos.
Detección de movimiento y sonido Mira y escucha el movimiento y el sonido. Wyze Cam envía una alerta a su teléfono y comienza a grabar cuando se detecta.
Zonas de detección de movimiento
Supervise áreas específicas en busca de movimiento para que solo reciba notificaciones cuando sea importante.
Grabación continua 24/7
Capture y vea hasta 3 días de video continuo con una tarjeta microSD de 32 GB (se vende por separado).
Alertas de humo y CO
Reciba una alerta en el momento en que Wyze Cam escuche una alarma de humo o monóxido de carbono. Wyze Cam graba un video durante este tiempo.
