1 de 7
Wyze Cam Outdoor v2
Weatherproof outdoor security with 1080p Color Night Vision.
The best wire-free security camera. Now with Color Night Vision
Choose your configuration
TOTAL:
$227.000,00 Shipping Included
Features
  • 1080p HD Color Night Vision
  • IP65 Weather Resistance
  • 6-Month Battery Life
  • 130° Field of View
  • PIR Motion Detection
  • Two-Way Audio
  • 4 Cameras/Base Station
Tech Specs
Camera:
• Dimensions: 2.3 inch x 2.3 inch x 2.8 inch (5.842cm x 5.842 cm x 7.112cm)
• Item Weight: 9.8 ounces
• Sensor: 1/2.9’ Starlight CMOS
• Battery: 2x 2,600 mAh/7.4V rechargeable batteries
• Operating Temperature: -4℉ - 122℉
• Charging Temperature: 32℉ - 122℉
• IP Rating: IP65
• Resolution: 1920x1080 (1080p)
• Field of View: 130°
• Night Vision LEDs: 4*850nm LEDs
• Night Vision Distance: Up to 25 feet
• Daytime Video: 20 Frames Per Second
• Nighttime Video: 10 Frames Per Second
• Zoom: 8x digital
• One base station supports up to 4 cameras
• Local Storage: microSD card slot on camera and base station (up to 32GB)
• Mounting: Magnetic, Screw, or 3rd party 1⁄4" — 20 mount
• Certifications: FCC, IC, UL, and IP65 Certified
Base Station:
• Interface Port: Fast ethernet (10/100)
In the Box
Starter Bundle:
  • Wyze Cam Outdoor v2 x1
  • Base Station x1
  • Base Station Power Adapter(US Standard) x1
  • Base Station Ethernet Cable x1
  • microUSB Cable x1
  • Screw Assembly x1
  • Quick Start Guide x1
Add-on Camera:
  • microUSB Cable x1
  • Screw Assembly x1
Visión nocturna en color HD de 1080p
Campo de visión más amplio (130°)
Cobertura de detección de movimiento PIR
IP65 resistente a la intemperie
Compatible con la estación base v1
Luz de las estrellas. Color brillante.
Metraje sin editar. Filmado en Wyze Cam Outdoor v2.
Vea con extraordinario detalle, por la noche.
OMA v1
OMA v2
OMA v1
OMA v2
Wyze Cam Outdoor v1
Wyze Cam Outdoor v2
Sensor de luz estelar
El sensor Starlight CMOS ve en entornos hasta 25 veces más oscuros
Apertura ƒ/1.6
Revela más detalles por la noche al capturar 2 veces más luz
Proveedor de servicios de Internet Starlight
Reduce el ruido de la poca luz y agudiza la imagen para una claridad asombrosa.
Trae aguaceros, ventiscas y olas de calor: la Wyze Cam Outdoor está construida desde cero para ser un caballo de batalla incluso en las condiciones más duras.
A prueba de polvo
Protección total contra el polvo y otras partículas.
Impermeable
Protección contra chorros de agua a baja presión.
Calor/frío extremo
Totalmente funcional en climas de -4° hasta 122°F
Con hasta 6 meses de duración de la batería
Móntelo donde lo necesite, sin preocuparse por tender cables o encontrar tomas de corriente. 2 baterías recargables integradas de 2600 mAh que duran hasta 6 meses con una sola carga.
y carga continua con Wyze Solar Panel.
Todo superhéroe necesita un compañero. El panel solar Wyze convierte los rayos solares en energía para que pueda dejar su cámara encendida por más tiempo con carga menos frecuente. Con suficiente luz solar, es posible que nunca necesites quitarlo de nuevo.
Comprar panel solar Wyze
Reciba una notificación cuando se detecte movimiento
Wyze Cam Outdoor utiliza sensores infrarrojos pasivos (EL PUENTE) para detectar firmas de calor corporal para reducir las alertas falsas de cosas como ramas ondeantes. Cuando se detecte movimiento, recibirá una alerta enviada directamente a su teléfono, para que nunca se pierda nada.
y responda en tiempo real con audio bidireccional
Pídale al repartidor que esconda un paquete detrás de los arbustos, o asuste a los invitados no deseados en su jardín con la sirena incorporada.
Modo de viaje
¿Te alojas en un hotel o viajas de mochilero por las Montañas Rocosas? El modo de viaje le permite grabar videos de movimiento y de lapso de tiempo en una tarjeta MicroSD, incluso cuando no está conectado a Internet o a la estación base.
La aplicación Wyze es su centro de comando.
Ver transmisiones en vivo
Ingrese en cualquier momento y desde cualquier lugar para ver transmisiones de video en vivo.
Establecer zonas de detección de movimiento
Supervise áreas específicas en busca de movimiento para que solo reciba notificaciones cuando sea importante.
Es fácil instalar Wyze Cam Outdoor v2
¿Nervioso por la instalación? Lo entendemos. Solo mire nuestro video de instalación paso a paso a continuación para ver qué tan fácil es el proceso.
