1 de 5
Wyze Cam Pan v2
Pruébalo. Ahora con Visión Nocturna en Color.
Choose your estilo
TOTAL:
$108.000,00 + Envío
Devoluciones sin problemas de 15 días.
Features
Color Night Vision
Wyze Cam Pan v2’s Starlight CMOS Sensor helps you to see in ultra low-light conditions.
This camera is capable of seeing in color at night with very limited lighting. You can even use it to watch or even take a time lapse of the stars.
Pan/Tilt/Zoom
Use the control panel in the Wyze app to pan and tilt the camera for a 360° live view. Pinch zoom the live stream screen to zoom up to 8x. You can adjust the rotation speed (up to 110° per second) in the Wyze app.
Pan Scan
Wyze Cam Pan v2 automatically scans its surroundings by rotating to up to 4 custom waypoints. It pauses for 10 seconds at each waypoint before moving on to the next one.
1080p Full HD
Live streaming, recording, and playback are all available in clear and sharp 1080p HD resolution. Toggle between SD and HD to fit your needs.
Motion Tracking
Wyze Cam Pan v2 auto-tracks any moving object detected within its field of view. You can turn this feature on or off in the Wyze app.
Motion Tagging
Highlight motion in both Live Stream and Playback modes.
Live Streaming
View what’s going on in real time and record videos or take pictures saved directly to your phone.
Real 2-Way Audio
Say goodbye to push-to-talk.
Wyze Cam Pan v2 has simultaneous 2-way communication. Talking to your family, pets, and visitors is just like making a phone call.
Night Vision
Wyze Cam Pan v2’s enhanced night vision distinguishes 18 variations of gray and provides clear images up to 30 feet away.
Motion and Sound Detection
When the camera detects motion or sound, it will record a 12-second video that is securely stored in the AWS cloud.
Motion Detection Zone
Create a custom detection zone to only trigger Event Videos for motion detected within a specific area of the camera’s field of view.
Smart Sound Recognition
Wyze Cam Pan v2 recognizes the unique tonal patterns of smoke alarms and CO monitors to alert you to these specific emergencies.
Push Notifications
Receive a push notification to view an Event Video when motion or sound is detected and recorded.
Alert Scheduling
Set an alert schedule to automatically turn on and off motion and sound detection at specific times of the day.
Free, Rolling, 14-Day Cloud Storage
You have free access to saved motion and sound-triggered Event Videos for rolling 14 days for the life of the product.
Secure AWS Cloud Storage
Wyze Cam Pan v2 uses end-to-end encryption for uploading and downloading Event Videos to and from the AWS cloud.
Continuous Recording
Footage can be recorded and stored to a microSD card (sold separately) continuously. Older files are automatically overwritten when storage reaches capacity.
Time Lapse
Set the time frame and intervals to easily create custom time lapse videos and save them locally to a microSD card (sold separately).
Playback
When a microSD card (not included) is installed, users can view videos in Playback mode by scrolling through the timeline and pinch zoom the timeline for easier navigation.
Sharing
Use the Wyze app to share your camera with other users.
Flexible Installation
The ¼” – 20 threaded screw hole in Wyze Cam Pan v2’s base works with standard camera mounts and can be mounted to any surface.
Mini-Siren Feature
Use the improved speaker as a siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
Tech Specs
Wyze Cam Pan v2 Device Details
Color
White
Finish
Matte
Materials
Body: Polycarbonate
Lens: Glass + plastic
Camera Dimensions
127.5 mm (H) x 60 mm (W) x 60 mm (D)
Camera Weight
8.78 oz (249 g)
Ports
1 micro USB
LED indicator
Front: Red + Blue.
Phone Compatibility
Android 7.0+
iOS 12.0+
Night Vision
IR Lights: 6x940 nm
Illuminates up to 29.6 feet (9 m)
Day/Night Vision
Audio
Built-in speaker and microphone
Class-D power amplifier
Powering Methods
Power Cable Length: 6 feet (1.8 m)
Power Adapter Input: 110-240V (AC/DC)
Power Adapter Output: 5V/2000mA
Base Screw Hole
1/4″ – 20
CPU
1.5GHz
Memory
128 Mb
Camera
Resolution: 1920 X 1080 (1080p)
Lens: F1.6 aperture, 3.2mm focal length
Image Sensor: 1/2.9'' CMOS
Digital zoom: 8x
Field of View: 120° lens
Rotation Speed
Up to 110° per second
View Range: 360° horizontal, 93° vertical
Audio
Video
H.264 encoding
Day time video: 20 FPS
Night vision: 15 FPS
Alerts
Push notifications
Cloud Storage
Free rolling 14 days of alert videos stored in the AWS Cloud
Local Storage
Supports 8 GB, 16 GB and 32 GB microSD cards in FAT32 format
Data Security
End-to-end encryption
HTTPS secure transfer protocol
AES 128-bit encryption
Data Usage
1-2 MB per minute in SD, or 4-7 MB per minute in HD
WiFi
802.11 b/g/n 2.4 GHz (Does not support 5 GHz network)
Supports WPA and WPA2 protocols
Connectivity Requirements
Upload speed is 1.0 Mbps for SD and 1.5 Mbps for HD
Operating Systems
Supports iOS 12.0 and Android 7.0 or later
Operating Temperature
32℉ – 104℉ / 0°C – 40 °C
Operating Humidity
<90% at 104℉ / 40°C
Weather Resistance
Indoor use only
Certifications
FCC, IC, UL
Languages
English
Warranty
1-Year
In the Box
  • Wyze Cam Pan v2 x1
  • 6′ Micro USB Cable x1
  • Power Adapter x1
  • Quick Start Guide x1
Pan Tilt
Alcance horizontal de 360° y vertical de 93°.
Visión nocturna en color de 1080p
Vea más claramente por la noche a todo color.
Luces infrarrojas invisibles
Sutil y discreto por la noche.
Centrado en la seguridad
Diseñado pensando en la seguridad.
Ver toda la habitación en menos de 3 segundos
Sigue la acción dondequiera que vaya con el seguimiento de movimiento automático y una cobertura de 360°. Es como tener una lechuza de guardia las 24 horas del día, los 7 días de la semana. Excepto que no tienes que alimentarlo con Tootsie Pops.
Deja que Pan Scan™
Patrulle su habitación con Pan Scan™. Configure la ruta de patrulla de la cámara con hasta 4 puntos de referencia personalizados.
Captura cada historia en color, incluso de noche.
Di adiós a los clips en blanco y negro que parecen secuencias de noticieros antiguos. Nuestro galardonado Starlight Sensor ilumina los detalles a todo color incluso con poca luz.
Wyze Cam Pan
Wyze Cam Pan v2
Wyze Cam Pan
Wyze Cam Pan v2
Wyze Cam Pan
Wyze Cam Pan v2
  • Sensor de luz estelar
    El sensor Starlight CMOS ve en entornos tan oscuros como 0,1 lux
  • Apertura ƒ/1.6
    Revela más detalles por la noche al capturar más luz
  • Amplio campo de visión
    120º FOV ve la imagen completa.
Conectar y proteger
Salude, ordene y elogie a sus hijos de dos o cuatro patas desde cualquier lugar como un padre helicóptero nada ansioso. Presione el botón de sirena en la aplicación Wyze para asustar a los invitados no deseados.
¿Conoces esos puntos rojos que se encienden cuando una cámara cambia a visión nocturna y se parece a Terminator? Sí, el nuestro no hace eso. Las luces Wyze Cam Pan v2 permanecen invisibles para que no molesten a los amigos peludos ni a la bebé Sarah Connors.
Seguimiento automático de la acción.
¡Ardilla! Detecta y rastrea automáticamente el movimiento como un perro guardián con cafeína. ¡La potencia de procesamiento reforzada sigue el movimiento en tiempo real más rápido que nunca!
Y aún más funciones inteligentes.
Grabación continua 24/7
Capture y vea hasta 3 días de video continuo con una tarjeta microSD de 32 GB (se vende por separado).
Notificaciones instantáneas
Wyze Cam Pan v2 graba automáticamente un video de evento de 12 segundos cuando detecta movimiento o sonido. Active las notificaciones automáticas para estar al tanto de las cosas sin tener que monitorear constantemente la aplicación.
Alertas de humo y CO
Reciba una alerta en el momento en que Wyze Cam Pan escuche una alarma de humo o CO. Configúrelo para grabar un video durante este tiempo.
