1 de 6
Wyze Outdoor Power Adapter
Ready for rain, snow, or shine. Wyze Cam v3 and OG series use Adapter v1. Wyze Cam Pan v3 and Cam v3 Pro use Adapter v2.
Choose your style
TOTAL:
$70.000,00 + Shipping
Features
  • Easy installation, as simple as plugging it in
  • Works with Wyze Cam v3 or Wyze Cam v3 Pro
  • IP67 Weather Resistant
Tech Specs
  • Color: White
  • Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
  • Weight: 235 g
  • Cable Length:
    Total cable length: 12.5 ft (3.8 m)
    AC cable length: 3.9 ft (1.2 m)
    DC cable length 8.5 ft (2.6 m)
  • Compatibility: Works with Wyze Cam v3
  • Powering Methods:
    Input power: 100v-240v
    Output power: 5v2A
    Connector to camera: Micro USB
    Connector to wall plug: 2 pin flat, US
  • Operating Temperature: -22℉ - 122℉ (-30°C - 50°C)
  • Weather Resistance: IP67 Weather Resistant
  • Certification: FCC, UL
  • Warranty: 1-Year
In the Box
  • Wyze Outdoor Power Adapter x 1
  • Wire Clip x 8
  • Screw x 6
  • Attached Cable Wrap (White) x 2
  • Screw Anchor x 6
