Wyze Outdoor Power Adapter
Ready for rain, snow, or shine. Wyze Cam v3 and OG series use Adapter v1. Wyze Cam Pan v3 and Cam v3 Pro use Adapter v2.
TOTAL:
¥3,400
+ Shipping
30日間の手間のかからない返品。
Features
- Easy installation, as simple as plugging it in
- Works with Wyze Cam v3 or Wyze Cam v3 Pro
- IP67 Weather Resistant
Tech Specs
- Color: White
- Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
- Weight: 235 g
- Cable Length:
Total cable length: 12.5 ft (3.8 m)
AC cable length: 3.9 ft (1.2 m)
DC cable length 8.5 ft (2.6 m) - Compatibility: Works with Wyze Cam v3
- Powering Methods:
Input power: 100v-240v
Output power: 5v2A
Connector to camera: Micro USB
Connector to wall plug: 2 pin flat, US - Operating Temperature: -22℉ - 122℉ (-30°C - 50°C)
- Weather Resistance: IP67 Weather Resistant
- Certification: FCC, UL
- Warranty: 1-Year
In the Box
- Wyze Outdoor Power Adapter x 1
- Wire Clip x 8
- Screw x 6
- Attached Cable Wrap (White) x 2
- Screw Anchor x 6
- 選択結果を選ぶと、ページが全面的に更新されます。
