Pular para as informações do produto
1 de 7
Wyze Cam Outdoor v2
Weatherproof outdoor security with 1080p Color Night Vision.
The best wire-free security camera. Now with Color Night Vision
Choose your configuration
TOTAL:
$227.000,00 Shipping Included
Devoluções sem complicações em 30 dias.
Features
  • 1080p HD Color Night Vision
  • IP65 Weather Resistance
  • 6-Month Battery Life
  • 130° Field of View
  • PIR Motion Detection
  • Two-Way Audio
  • 4 Cameras/Base Station
Tech Specs
Camera:
• Dimensions: 2.3 inch x 2.3 inch x 2.8 inch (5.842cm x 5.842 cm x 7.112cm)
• Item Weight: 9.8 ounces
• Sensor: 1/2.9’ Starlight CMOS
• Battery: 2x 2,600 mAh/7.4V rechargeable batteries
• Operating Temperature: -4℉ - 122℉
• Charging Temperature: 32℉ - 122℉
• IP Rating: IP65
• Resolution: 1920x1080 (1080p)
• Field of View: 130°
• Night Vision LEDs: 4*850nm LEDs
• Night Vision Distance: Up to 25 feet
• Daytime Video: 20 Frames Per Second
• Nighttime Video: 10 Frames Per Second
• Zoom: 8x digital
• One base station supports up to 4 cameras
• Local Storage: microSD card slot on camera and base station (up to 32GB)
• Mounting: Magnetic, Screw, or 3rd party 1⁄4" — 20 mount
• Certifications: FCC, IC, UL, and IP65 Certified
Base Station:
• Interface Port: Fast ethernet (10/100)
In the Box
Starter Bundle:
  • Wyze Cam Outdoor v2 x1
  • Base Station x1
  • Base Station Power Adapter(US Standard) x1
  • Base Station Ethernet Cable x1
  • microUSB Cable x1
  • Screw Assembly x1
  • Quick Start Guide x1
Add-on Camera:
  • microUSB Cable x1
  • Screw Assembly x1
Visão noturna colorida HD 1080p
Campo de visão mais amplo (130°)
Cobertura de detecção de movimento PIR
IP65 à prova de intempéries
Compatível com estação base v1
Luz das estrelas. Cor Brilhante.
Filmagens não editadas. Filmado em Wyze Cam Outdoor v2.
Veja em detalhes extraordinários, à noite.
WCO v1
WCO v2
WCO v1
WCO v2
Wyze Cam Outdoor v1
Wyze Cam Outdoor v2
Sensor de luz das estrelas
O sensor Starlight CMOS enxerga em ambientes até 25x mais escuros
ƒ/1,6 abertura
Revela mais detalhes à noite, capturando 2x mais luz
Starlight ISP
Reduz o ruído de pouca luz e aguça a imagem para uma clareza surpreendente.
Traga as chuvas, nevascas e ondas de calor - o Wyze Cam Outdoor foi construído desde o início para ser um cavalo de batalha mesmo nas condições mais adversas.
À prova de poeiras
Proteção total contra poeira e outras partículas.
À prova d'água
Proteção contra jatos de água de baixa pressão.
Calor/Frio Extremo
Totalmente funcional em climas de -4 ° até 122 ° F
Com até 6 meses de duração da bateria
Monte onde você precisar, sem se preocupar em passar fios ou encontrar tomadas. 2 baterias recarregáveis integradas de 2.600 mAh duram até 6 meses com uma única carga.
e carregamento contínuo com o Wyze Solar Panel.
Todo super-herói precisa de um ajudante. O Wyze Solar Panel converte os raios solares em energia para que você possa deixar sua câmera ligada por mais tempo com carregamento menos frequente. Com luz solar suficiente, talvez você nunca precise desligá-lo novamente.
Compre o painel solar Wyze
Seja notificado quando o movimento for detectado
Wyze Cam Outdoor usa sensores infravermelhos passivos (A PONTE) para detectar assinaturas de calor corporal para reduzir alertas falsos de coisas como galhos ondulantes. Quando o movimento for detectado, você receberá um alerta enviado diretamente para o seu telefone, para que você nunca perca nada.
e responda em tempo real com áudio bidirecional
Peça ao entregador para esconder um pacote atrás dos arbustos ou afugente os hóspedes indesejados em seu quintal usando a sirene embutida.
Modo de viagem
Ficar em um hotel ou mochilar nas Montanhas Rochosas? O Modo Viagem permite gravar vídeos de movimento e lapso de tempo em um cartão MicroSD, mesmo quando você não está conectado à Internet ou à estação base.
O aplicativo Wyze é seu centro de comando.
Ver transmissões ao vivo
Entre a qualquer hora, de qualquer lugar para ver feeds de vídeo ao vivo.
Definir zonas de detecção de movimento
Monitore áreas específicas para movimento para que você só receba notificações quando for importante.
É fácil instalar Wyze Cam Outdoor v2
Nervoso com a instalação? Nós entendemos. Basta assistir ao nosso vídeo de instalação passo a passo abaixo para ver como o processo é realmente fácil.
