Pular para as informações do produto
1 de 5
Wyze Cam Pan v2
Leve-o para dar uma volta. Agora com Visão Noturna Colorida.
Choose your estilo
TOTAL:
$108.000,00 + Envio
Devoluções sem complicações em 15 dias.
Features
Color Night Vision
Wyze Cam Pan v2’s Starlight CMOS Sensor helps you to see in ultra low-light conditions.
This camera is capable of seeing in color at night with very limited lighting. You can even use it to watch or even take a time lapse of the stars.
Pan/Tilt/Zoom
Use the control panel in the Wyze app to pan and tilt the camera for a 360° live view. Pinch zoom the live stream screen to zoom up to 8x. You can adjust the rotation speed (up to 110° per second) in the Wyze app.
Pan Scan
Wyze Cam Pan v2 automatically scans its surroundings by rotating to up to 4 custom waypoints. It pauses for 10 seconds at each waypoint before moving on to the next one.
1080p Full HD
Live streaming, recording, and playback are all available in clear and sharp 1080p HD resolution. Toggle between SD and HD to fit your needs.
Motion Tracking
Wyze Cam Pan v2 auto-tracks any moving object detected within its field of view. You can turn this feature on or off in the Wyze app.
Motion Tagging
Highlight motion in both Live Stream and Playback modes.
Live Streaming
View what’s going on in real time and record videos or take pictures saved directly to your phone.
Real 2-Way Audio
Say goodbye to push-to-talk.
Wyze Cam Pan v2 has simultaneous 2-way communication. Talking to your family, pets, and visitors is just like making a phone call.
Night Vision
Wyze Cam Pan v2’s enhanced night vision distinguishes 18 variations of gray and provides clear images up to 30 feet away.
Motion and Sound Detection
When the camera detects motion or sound, it will record a 12-second video that is securely stored in the AWS cloud.
Motion Detection Zone
Create a custom detection zone to only trigger Event Videos for motion detected within a specific area of the camera’s field of view.
Smart Sound Recognition
Wyze Cam Pan v2 recognizes the unique tonal patterns of smoke alarms and CO monitors to alert you to these specific emergencies.
Push Notifications
Receive a push notification to view an Event Video when motion or sound is detected and recorded.
Alert Scheduling
Set an alert schedule to automatically turn on and off motion and sound detection at specific times of the day.
Free, Rolling, 14-Day Cloud Storage
You have free access to saved motion and sound-triggered Event Videos for rolling 14 days for the life of the product.
Secure AWS Cloud Storage
Wyze Cam Pan v2 uses end-to-end encryption for uploading and downloading Event Videos to and from the AWS cloud.
Continuous Recording
Footage can be recorded and stored to a microSD card (sold separately) continuously. Older files are automatically overwritten when storage reaches capacity.
Time Lapse
Set the time frame and intervals to easily create custom time lapse videos and save them locally to a microSD card (sold separately).
Playback
When a microSD card (not included) is installed, users can view videos in Playback mode by scrolling through the timeline and pinch zoom the timeline for easier navigation.
Sharing
Use the Wyze app to share your camera with other users.
Flexible Installation
The ¼” – 20 threaded screw hole in Wyze Cam Pan v2’s base works with standard camera mounts and can be mounted to any surface.
Mini-Siren Feature
Use the improved speaker as a siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
Tech Specs
Wyze Cam Pan v2 Device Details
Color
White
Finish
Matte
Materials
Body: Polycarbonate
Lens: Glass + plastic
Camera Dimensions
127.5 mm (H) x 60 mm (W) x 60 mm (D)
Camera Weight
8.78 oz (249 g)
Ports
1 micro USB
LED indicator
Front: Red + Blue.
Phone Compatibility
Android 7.0+
iOS 12.0+
Night Vision
IR Lights: 6x940 nm
Illuminates up to 29.6 feet (9 m)
Day/Night Vision
Audio
Built-in speaker and microphone
Class-D power amplifier
Powering Methods
Power Cable Length: 6 feet (1.8 m)
Power Adapter Input: 110-240V (AC/DC)
Power Adapter Output: 5V/2000mA
Base Screw Hole
1/4″ – 20
CPU
1.5GHz
Memory
128 Mb
Camera
Resolution: 1920 X 1080 (1080p)
Lens: F1.6 aperture, 3.2mm focal length
Image Sensor: 1/2.9'' CMOS
Digital zoom: 8x
Field of View: 120° lens
Rotation Speed
Up to 110° per second
View Range: 360° horizontal, 93° vertical
Audio
Video
H.264 encoding
Day time video: 20 FPS
Night vision: 15 FPS
Alerts
Push notifications
Cloud Storage
Free rolling 14 days of alert videos stored in the AWS Cloud
Local Storage
Supports 8 GB, 16 GB and 32 GB microSD cards in FAT32 format
Data Security
End-to-end encryption
HTTPS secure transfer protocol
AES 128-bit encryption
Data Usage
1-2 MB per minute in SD, or 4-7 MB per minute in HD
WiFi
802.11 b/g/n 2.4 GHz (Does not support 5 GHz network)
Supports WPA and WPA2 protocols
Connectivity Requirements
Upload speed is 1.0 Mbps for SD and 1.5 Mbps for HD
Operating Systems
Supports iOS 12.0 and Android 7.0 or later
Operating Temperature
32℉ – 104℉ / 0°C – 40 °C
Operating Humidity
<90% at 104℉ / 40°C
Weather Resistance
Indoor use only
Certifications
FCC, IC, UL
Languages
English
Warranty
1-Year
In the Box
  • Wyze Cam Pan v2 x1
  • 6′ Micro USB Cable x1
  • Power Adapter x1
  • Quick Start Guide x1
Pan & Inclinação
Faixa horizontal de 360° e vertical de 93°.
Visão noturna colorida 1080p
Veja mais claramente à noite em cores.
Luzes infravermelhas invisíveis
Sutil e discreto à noite.
Foco na segurança
Projetado com segurança em mente.
Veja toda a sala em menos de 3 segundos
Acompanhe a ação onde quer que ela vá com rastreamento automático de movimento e cobertura de 360°. É como ter uma coruja de guarda de plantão 24 horas por dia, 7 dias por semana. Exceto que você não precisa alimentá-lo com Tootsie Pops.
Deixe Pan Scan™
Patrulhe seu quarto com Pan Scan™. Defina a rota de patrulha da câmera com até 4 waypoints personalizados.
Pegue todas as histórias em cores, mesmo à noite.
Diga adeus aos clipes em preto e branco que parecem filmagens de noticiários vintage. Nosso premiado Starlight Sensor ilumina os detalhes em cores, mesmo com pouca luz.
Wyze Cam Pan
Wyze Cam Pan v2
Wyze Cam Pan
Wyze Cam Pan v2
Wyze Cam Pan
Wyze Cam Pan v2
  • Sensor de luz das estrelas
    O sensor Starlight CMOS vê em ambientes tão escuros quanto 0,1 lux
  • ƒ/1,6 abertura
    Revela mais detalhes à noite, capturando mais luz
  • Campo de visão amplo
    120º FOV vê a imagem inteira.
Conecte e proteja
Cumprimente, comande e elogie seus filhos de duas ou quatro patas de qualquer lugar, como um pai helicóptero nada ansioso. Pressione o botão da sirene no aplicativo Wyze para assustar convidados indesejados.
Sabe aqueles pontinhos vermelhos que acendem quando uma câmera muda para visão noturna e parece o Exterminador do Futuro? Sim, o nosso não faz isso. As luzes Wyze Cam Pan v2 permanecem invisíveis para que não perturbem os amigos peludos ou o bebê Sarah Connors.
Acompanhe automaticamente a ação.
Esquilo! Detecte e rastreie automaticamente o movimento como um cão de guarda cafeinado. O poder de processamento reforçado segue o movimento em tempo real mais rápido do que nunca!
E ainda mais recursos inteligentes.
Gravação Contínua 24/7
Capture e visualize até 3 dias de vídeo contínuo com um cartão microSD de 32 GB (vendido separadamente).
Notificações instantâneas
Wyze Cam Pan v2 grava automaticamente um vídeo de evento de 12 segundos quando detecta movimento ou som. Ative as notificações push para ficar por dentro das coisas sem precisar monitorar constantemente o aplicativo.
Alertas de fumaça e CO
Receba um alerta no momento em que o Wyze Cam Pan ouvir um alarme de fumaça ou CO disparar. Configure-o para gravar um vídeo durante esse período.
