Wyze Solar Panel
Record for longer. Designed for Wyze Cam Outdoor v1 or Wyze Cam Outdoor v2.
TOTAL:
$90.000,00
30 dias de devolução sem complicações.
Features
- Extend the length of time you can keep your Wyze Cam Outdoor recording without having to bring it back inside to recharge.
- IP65 weather resistant and dustproof.
- Mount it anywhere with a 360 degree freestyle mount and a 13-foot weatherproof power cable.
User Guide
- Wyze Cam Outdoor recharge frequency varies based on device settings, motion notifications, and sun exposure in the area of placement.
- For the most sunlight, position your Wyze Solar Panel so that it’s facing south and is tilted upward at a 30º angle.
- Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
Tech Specs
- Color: White
- Dimensions: 173 mm x 120 mm x 17 mm
- Solar power rating: 2.5W, 5VDC
- Micro USB cable length: 13 ft (4m)
- Waterproof level: IP65
In the Box
- Solar panel x1
- Wall mount x1
- Adapter cable x1
- Screws x3
- Wall anchors x3
- Quick start guide x1
- Ao escolher uma seleção, a página inteira é atualizada.
